Alphacool Eiswolf 2 AIO - 360mm RTX 4090 Aorus Master - Gaming with Backplate
  • 13477
  • 4250197134774
  • 5,23 kg
€159.98 * €269.98 * (40.74% Saved)
€59.98*
12948 Alphacool Eisblock XPX Aurora Edge - Acryl Black Digital RGB
€59.98*
ROH Alphacool Eisbaer TPV Extension Set (hose and connections)
€15.39*
WAKZ Alphacool Aurora Vertical GPU Mount with Riser Cable
€74.98*
WZS Alphacool spray bottle Core 500ml
€4.98*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
Attention: Not compatible with the PCB V1.1!
- Gigabyte AORUS GeForce RTX 4090 Master 24G, 24GB GDDR6X (GV-N4090AORUS M-24GD)
- Gigabyte GeForce RTX 4090 Gaming OC 24G, 24GB GDDR6X (GV-N4090GAMING OC-24GD)
Technical data radiator
Dimensions (L x W x H)395 x 124 x 30mm (+/- 3%)
Material cooling fins, chambers & channelsCopper
Material threadsBrass
G 1/4“ threads2 x for tubes (+ 1x Fillport G1/4“)
For fan size120 mm
Options for fan assembly3 x one-sided / 6 x both-sided
Technical data cooler and pump
Dimensions (L x W x H)233,30 x 162,06 x 47,40mm
Material cooler bottomChrome plated copper
Material cooler topacrylic
Threads2 x G1/4“
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5V DC
Power consumption3.2W
MTBF50.000 h
Technical data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 C° / +90 °C
Technical data quick fasteners
Dimensions (L x D)95 x 27mm
MaterialNylon
For tube size12,7 / 7,6mm
ColorBlack
Technical data fittings
L x D straight fitting24 x 18mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17mm
Quantity 90° fittings2x
Material fittingsBrass
Technical data tube
Length50cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12,7 / 7,6mm
Hardness grade35 Shore-A to 50 Shore-D
Working temperature-50 to +155 °C
Technical data fan
Speed0 - 2500 RPM
Static pressure3,17 mm H2O
Air flow rate119,8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Dimensions (L x W x H)120 x 120 x 25mm
Net weight187g
Max working temperature60°C
Manufacturer: Alphacool
Radiator dimensions: 395 x 124 x 30mm
Radiator thickness: 29 - 39mm
Radiator size: 360mm
Hose dimensions: 12,7/7,6mm
Base: Nvidia GeForce
Prefilled: Yes
Content 2 Stück (€7.70 * / 1 Stück)
€15.39 *
Content 330 Zentimeter (€5.75 * / 100 Zentimeter)
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
25%
KOI Alphacool Core Ocean T38 AIO 360mm
€56.98 * €75.98 *
S16 Alphacool Carbon HardTube 16mm 4x 80cm
Content 80 Zentimeter (€43.71 * / 100 Zentimeter)
€34.97 * €49.98 *
Content 2 Stück (€12.49 * / 1 Stück)
€24.98 *
€6.49 * €8.98 *
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - Ultra Clear 3m (9.8ft) retail box 300cm
€37.98 *
€34.98 *
Liefertermin: in 6 - 7 Wochen
34%
Alphacool Ice Cyclone Aurora LUX Digital RGB - Kit of 3 (120x120x25mm)
Content 3 Stück (€8.66 * / 1 Stück)
€25.98 * €39.25 *
