Alphacool Eiszapfen temperature sensor plug G1/4 - Deep Black
- Article no.: 17365
- EAN: 4250197173650
- Weight: 0,025 kg
Alphacool Eisfluegel temperature sensor
A sensor that is simply screwed into a G1/4" thread. With cable and 2-pin connection.
Can be used in all exposed G1/4" threaded openings on the radiator, expansion tank or in a T-piece that is integrated in the circuit.
Fully encapsulated and therefore completely sealed. Thanks to nickel plating - no corrosion problems! Full functionality with any PC temperature indicator that is compatible with standard PC temperature indicators! Control your PC INDEPENDENTLY of the BIOS sensors: This is double protection, similar to the well-known "redundancy" (double security) in the professional sector."
Long (50cm) connection cable, also suitable for big towers!
Scope of delivery :
- 1x Alphacool Eiszapfen temperature sensor plug G1/4 - Deep Black
It is a 10kOhm temperature sensor that is compatible with the following devices, among others:
- aquaero 3.07, aquaero 4.00
- aquastream XT Ultra
- aquaduct variants with external sensor input (360 XT, 720 XT)
- Alphacool Heatmaster
- Innovatek Fan-O-Matic
- Lian Li Multipanel
- Scythe Kaze
- T-Balancer
- Sensor inputs of many motherboards
RT Sensor Table: Open the PDF
1st page: | G1/4" external thread |
2nd page: | Unavailable |
Liefertermin: in 8 - 9 Wochen
