Alphacool pump adaptor
  • 25066
  • 4250197136372
  • 0,051 kg
€5.28 *
The pump adaptor allows connection of pumps with a 4-Pin Molex plug (same as e.g. the DCD-ROM... more
The pump adaptor allows connection of pumps with a 4-Pin Molex plug (same as e.g. the DCD-ROM power connector) to controllers with a 3-Pin fan connector such as the Alphacool Heatmaster including the rpm signal.
Also compatible with pumps without a rpm signal.
Alphacool VPP655 - PWM - Single Edition
€99.98 *
€1.68 *
WAC Alphacool Core XP³ Acetal
€29.98 *
20%
€3.97 * €4.97 *
23%
PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP/D5 Apex PWM Pumpe
Alphacool Core 200 Aurora reservoir acetal/acrylic with Apex pump
€95.98 * €124.99 *
Content 6 Stück (€5.00 * / 1 Stück)
€29.98 *
KOI Alphacool Eisbaer Aurora 360 CPU - Digital RGB PHT EOL
€178.98 *
