Phobya 2pin cable extension socket/plug - 30cm
- Article no.: ZK
- EAN: 4049469081096
- Weight: 0,019 kg
- Available:
This 2-pin extension is required for sensors that are too far away from the mainboard or reading device. Especially with large housings or if you want to lay the cables out of sight, it is difficult to manage without an extension.
Of course, this extension can also be used for other areas. For example, for the speaker on the housing or the reset or power button.
Technical details:
Connectors: 2 pin to 2 pole extension
Color: black
Dimensions: 30cm
RoHS compliant
1x Phobya 2pin cable extension socket/plug - 30cm
Liefertermin: in 6 - 7 Wochen
