Alphacool Core Geforce RTX 5090 Reference with backplate
- Article no.: 10242
- EAN: 4250197102421
- Weight: 1,704 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- Inno3D GeForce RTX™ 5090 iChill Frostbite (C50903-32D7X-1759FB)
- Inno3D GeForce RTX™ 5090 iChill X3 (C50903-32D7X-175967H)
- Inno3D GeForce RTX™ 5090 X3 (N50903-32D7-17593928)
- Inno3D GeForce RTX™ 5090 X3 OC (N50903-32D7X-17593928)
- MSI GeForce RTX™ 5090 32G VENTUS 3X OC (MS-V530 VER:1.1)
| Technical data cooler | |
| Dimensions total (L x W x H) | 201,40 x 148,57 x 34,38mm |
| Material terminal | Acetal |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 9 |
| Color | transparent |
| Dimensions (L x W x H) | 201,40 x 120 x 6mm |
| Thick backplate without spacers | 3mm |
| Material | Aluminium |
