Alphacool Apex Stealth Metal Fan 2000rpm Matt Black (120x120x25mm)
  • 13819
  • 4250197138192
  • 0,2 kg
€19.98 * €29.98 * (33.36% Saved)
RAD Alphacool NexXxoS HPE-30 Full Copper 360mm Radiator
€109.98*
LZ Alphacool Core 10x 4-Pin PWM Splitter with SATA power connector
€11.98*
LK Alphacool Y-Splitter 3-Pin to 3x 3-Pin 30cm
€2.98*
L12 Alphacool Apex Stealth Metal Fan 2000rpm Matt Black (120x120x25mm) 3x
Instead of €59.94 * (10% saved) Price for all: €53.94 *
Whisper Quiet
Powerful All-rounder
The Alphacool Apex Stealth metal fan is a true all-rounder. It sets new standards in terms of airflow and static pressure. Therefore, this fan is not only perfect for mounting on radiators, but also provides excellent airflow as a case fan. The Apex Stealth can be controlled between 400 to 2000 rpm via the 4-pin PWM connector. The startup speed is ~420 rpm. In addition, the Stealth offers Zero RPM control, which can be used to bring the fan to a complete stop.
Apex Design
Additional Features
Dimensions (L x W x H)120 x 120 x 25,5mm
Material (Frame)Die-cast zinc
Material (Impeller)Plastic
Weight320g
Speed400~2000±10% rpm
BearingHydro Dynamic Bearing
Connection4-Pin PWM
Start-up Voltage6 V DC
Rated Volt12 V DC
Power Consumption2.64 Watt
Rated Current0.20 A (0.22Max)
Air Flow47 CFM
Static Air Pressure2,09 mmH2O
Noise Level24.6 dBA
MTBF100,000h
PWM controlYes
Zero RPM controlYes
Tacho SignalYes
Auto-restartYes
Colormatte black
Warranty: 5 years
Awards & Videos
Rated speed range: 400 - 2000 U/min
Air conveying area: 50 - 99 m³/h
Air flow rate: 79,853 m³/h
Pressure: 2,09mm H2O
Color Frame: Black;
Rated speed: 2000 U/min
Color Rotor: Black;
Nominal voltage: 12V DC
Volume: 24,6 dB(A)
RPM signal transmission: Yes
Volume range: 20 - 29,9 dB(A)
Lebensdauer (bei 25°C): 100.000 h
Power connection: 4-pin;
Dimensions: 120 x 120 x 25mm
LED: Unavailable;
Power consumption: 2,64W
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
€2.98 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 30cm
€3.47 *
€33.98 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 15cm
€2.48 *
€6.28 *
€23.98 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
WAC Alphacool Core 1 LT Aurora Acryl
Alphacool Core 1 LT Aurora Acrylic
GHE Alphacool Apex Pro Skeleton Carbon Gehäuse
Alphacool Apex Pro Skeleton Carbon Case
€999.98 *
WAC Alphacool Core 1 Silver
€99.98 *
Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
