  • 12456
  • 4250197124560
  • 0,031 kg
€21.98 *
Content: 48 cm² (€0.46 * / 1 cm²)
Fastening: Slightly adhesive
Thickness: 1,0mm
Surface dimensions: 120 x 20mm
Thermal conductivity: 11W/mk
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x0,5mm - 2 Stück
Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.31 * / 1 cm²)
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück
Content 48 cm² (€0.60 * / 1 cm²)
€28.98 *
Liefertermin: in 2 - 3 Wochen
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1,5mm
Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x1.5mm
Content 100 cm² (€0.50 * / 1 cm²)
€49.98 *
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
€6.99 *
WAR Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x0,5mm - 2 Stück
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.62 * / 1 cm²)
€29.98 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1mm
Content 100 cm² (€0.35 * / 1 cm²)
€34.97 *
Alphacool HF screw plug G1/4 - Deep Black
€1.68 *
Liefertermin: in 8 - 9 Wochen
WAK Alphacool Core Geforce RTX 5090 Solid + AMP mit Backplate
Alphacool Core Geforce RTX 5090 Solid + AMP with backplate
€199.98 *
Liefertermin: in 9 - 10 Tagen
WAC Alphacool Apex 1 CPU Kühler AM5
Alphacool Apex 1 CPU cooler AM5
€169.98 *
20%
