Alphacool Eisschicht thermal pad - 17W/mK 100x100x1,5mm
- Article no.: 12467
- EAN: 4250197124676
- Weight: 0,077 kg
| Technical data | |
| Dimensions (L x W x H) | 100 x 100 x 1,5mm |
| Thermal conductivity | 17W/mK |
| Thickness | 1,5mm |
| Flame retardant | V-0 (UL94) |
| Useful temperature | -40 ~ +150 °C |
| Hardness | 72 (Shore OO) |
| Specific gravity | 3.2 |
| Breakdown voltage | 10 kV/mm |
| Elongation | 40 % |
| Tensile strength | 0.5 MPa |
| Volume resistivity | 1.0x10^11 Ohm-m |
| Fastening | slightly adhesive |
| Color | grey |
Delivery date: in 2 - 3 weeks
