Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x2mm
  • 13410
  • 4250197134101
  • 0,024 kg
  • Currently there are 6 available
€5.08 * €6.99 * (27.32% Saved)
Content: 16 cm² (€0.32 * / 1 cm²)
€4.28*
€69.98*
13405 Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88*
13407 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
€3.78*
13414 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
€5.58*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)40 x 40 x 2mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
€0.98 *
€1.19 *
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
22%
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x1,5mm
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1,5mm
Content 16 cm² (€0.29 * / 1 cm²)
€4.68 * €5.99 *
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1mm
Content 16 cm² (€0.22 * / 1 cm²)
€3.58 * €4.97 *
33%
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
Content 24 cm² (€0.20 * / 1 cm²)
€4.68 * €6.99 *
33%
€5.99 * €8.98 *
SZ Alphacool Silicon Bending Insert 150cm für ID 3/8" / 10mm HardTubes - Blau
Alphacool Silicon Bending Insert 150cm for ID 3/8" / 10mm HardTubes - Blue
Content 150 Zentimeter (€9.32 * / 100 Zentimeter)
32%
WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 40x40x0,5mm
Alphacool Core Thermal Pad Soft 9W/mk 40x40x0,5mm
Content 16 cm² (€0.26 * / 1 cm²)
€4.08 * €5.99 *
43%
€3.97 * €6.99 *
Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1,5mm
Content 24 cm² (€0.15 * / 1 cm²)
€3.68 * €4.97 *
47%
WÄM Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 120x20x1mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1mm
€3.68 * €6.99 *
€1.19 *
Delivery date: in 6 - 7 weeks
€39.98 *
WAO Alphacool MCX one
Alphacool MCX one
