Alphacool Ice Layer Thermal Pad - 17W/mK 120x20x0.5mm - 2 pieces
  • 12468
  • 4250197124683
  • 0,035 kg
€89.98 *
Content: 48 cm² (€1.87 * / 1 cm²)
€1.19 *
WÄM Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 Stück)
Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 pieces)
Content 36 cm² (€0.11 * / 1 cm²)
€3.78 *
21%
€33.97 * €42.98 *
21%
SZ Schlauchabschneider
hose cutter
€4.97 * €6.30 *
