- Article no.: 12460
- EAN: 4250197124607
- Weight: 0,072 kg
Fastening: | Slightly adhesive |
Thickness: | 1,5mm |
Surface dimensions: | 100 x 100mm |
Thermal conductivity: | 14W/mk |
Liefertermin: in 2 - 3 Wochen
