- Article no.: 12456
- EAN: 4250197124560
- Weight: 0,031 kg
Fastening: | Slightly adhesive |
Thickness: | 1,0mm |
Surface dimensions: | 120 x 20mm |
Thermal conductivity: | 11W/mk |
Liefertermin: in 8 - 9 Wochen
