Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x0.5mm - 2 pieces
- Article no.: 12454
- EAN: 4250197124546
- Weight: 0,37 kg
- Available: Currently there are 8 available
Delivery date: in 5 - 6 weeks
