Alphacool Icebox - Single Laing D5 - Rear Conversion Kit
  • 15306
  • 4250197153065
  • 0,235 kg
  • Currently there are 6 available
Alphacool Icebox - Single Laing D5 - Rear Conversion Kit Do you have the Alphacool icebox in... more
Do you have the Alphacool icebox in the DC-LT or DDC version and now want to upgrade to the D5 version? No problem with this conversion kit. Because as we know Alphacool, converting, expanding and renewing is no problem.
Simply remove the back of the ice compartment and attach the new D5 back. And you now have a system with the power of the D5 pump.
To the back:
On the right side of the back, two lighting modules for 5mm LEDs are placed behind the viewing window. This allows you to create a very unique look and illumination. On the left side there are also two openings for filling and draining the liquid. The last two 1/4" threads are for the inlet and outlet. A bubble down module has been placed behind the inlet to prevent turbulence that can bring air into the water circuit.
  • 1x Alphacool ice compartment - Single Laing D5 - rear conversion kit
€27.98 *
€5.48 *
17%
Alphacool Eiskamm Alu X5 Flat - 4mm silver - 4 pieces
€0.99 * €5.02 *
€0.99 * €5.02 *
90%
Alphacool Eiskamm Alu X16 - 4mm silver - 4 pieces
€0.99 * €9.94 *
86%
Alphacool Eiskamm Alu X8 - 4mm silver - 4 pieces
€0.99 * €6.96 *
Alphacool Eiskamm Alu X6 - 4mm silver - 4 pieces
€0.99 * €5.02 *
88%
€0.99 * €8.00 *
85%
€1.98 * €12.98 *
23%
Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
Content 30 Zentimeter (€33.27 * / 100 Zentimeter)
€9.98 * €12.98 *
44%
Alphacool AGB Universal Mount Clip-On 50mm - Black 2 pieces
Content 2 Stück (€2.24 * / 1 Stück)
€4.48 * €7.98 *
€29.98 *
