Alphacool Eisfach - Single Laing D5 with VPP Apex PWM pump
  • 13304
  • 4250197133043
  • 1,214 kg
€91.98 *
  Technical data Eisfach Material plastic, metal Color Black Dimensions (L... more
Materialplastic, metal
ColorBlack
Dimensions (L x W x H)148 x 132 x 84,5mm
Connection thread10x 1/4"
Lighting2x 5mm LED
Technical data VPP Apex
Dimensions (L x W x H)65x65x41mm
Material pump coveraluminium
Material axleceramics
Cable connections4-pin PWM | SATA
Cable lengths4-Pin PWM - 48cm | SATA - 48cm
Starting voltage12V DC
Maximum pumping head4.25m
Maximum flow rate340L/h
Weight276g
ColorBlack
€36.98 *
Delivery date: in 7 - 8 weeks
€29.98 *
€3.98 *
€5.48 *
Delivery date: in 9 - 10 days
Alphacool Eiszapfen 16/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
€33.98 *
€27.98 *
€6.49 * €8.98 *
€10.98 *
