Alphacool VPP655 - G1/4 inner thread including Eisdecke D5 - Acetal V.3
  • 13193
  • 4250197131933
  • 0,715 kg
€99.98 * €142.78 * (29.98% Saved)
Alphacools top for Laing D5 is now a member of the Eisdecke series and receives an update.... more
For years now this top is already a measure. Again and again, small improvements have been made. The second major update differs both, visually and technically in a few details.
The principle: On the bottom there is space for the Laing D5 or VPP655 pump and in the front or on top the inlet and outlet.
For even more flexibility, the Eisdecke gets three inlets and two outlets. Another feature is the new holder to give the entire unit a stable footing and complete the overall visual image. Optional installation in 3.5 "drive bay is possible.
The top can be converted by using the suplementary element, whitch is given as an accessory, to an complete reservoir which has also been revised.
Technical Details
  • Dimensions (LxWxH): 80 x 80 x 40mm
  • Dimensions with stands: 83 x 80 x 87mm
  • Material: Acetal
  • Threads: 5x ¼“
Alphacool VPP655
Alphacool's new power pump series, exceptional performance at an unbeatable price. The 12V pumps can simply be connected directly to the system PSU and the pump will start with your PC for maximum convenience and safety.
This pump is ideal for PC and other electronics water cooling. The DC pump is equipped with an electronically commutated spherical motor. In a pump with a spherical motor the only moving part is a spherically shaped rotor which in this pump is held in place by a bearing ball made of ultra-hard and wear-resistant ceramic. The spherical bearing of the rotor offers many advantages: For example an increase of bearing play is impossible due to the design, allowing the pump to run quietly and smoothly over its whole lifespan. A separate magnetic shielding of the pump is not needed.
The ball motor design allows efficient operation of the pump in combination with excellent performance. The pump can simply be connected to a 12V Molex connector of the system PSU.
The special feature of this model is the fact that only the pump core itself is shipped. Why pay more for all the things you won't need when using this pump with a third-party pump top?  Another feature is the ability to be adjusted in five speed settings.
Technical specifications
  • Dimensions (WxHxD): 65x65x57mm (without connectors)
  • Motor: Electronically commuted spherical motor
  • Rated voltage: 12V DC
  • Power consumption: 23W
  • Permitted voltage range: 8-24V DC
  • Pressure head at 12V: 3,7m
  • Maximum flow: 350l/h
  • Pumped media: Water, water/glycol mixtures
  • Maximum system temperature: 60°C
  • Materials: Stainless steel 1.4571, PPS-GF40, EPDM O-rings, Aluminium oxide, hard coal
  • Special features: Adjustable in five steps
  • Step 1: 1800 rpm
  • Step 2: 2550 rpm
  • Step 3: 3300 rpm
  • Step 4: 4050 rpm
  • Step 5: 4800 rpm
  • Power connector:  4 Pin Molex
Scope of delivery
  • Alphacool VPP655 - G1/4 inner thread including Eisdecke D5 - Plexi V.3
Mounting manual
Download 3D-file (.stp)
Notice
Not intended for continuous operation with fluids containing titanium dioxide or glycerin. Many pastel colours typically use these additives.
Spannung: 12V DC
Maximale Förderhöhe: Gut (2 bis 4m)
Zugelassene Flüssigkeiten: Wasser, Wasser/Glykol-Gemisch
Maximale Systemtemperatur: 60°C
Stromanschluss: 4Pin
Farbe: schwarz
Leistungsaufnahme: 23W
Maximaler Durchfluss: 1500 l/h
Abmessungen: 95 x 45 x 80mm
Wassereinlass: G1/4" Innengewinde
Wasserauslass: G1/4" Innengewinde
Möglicher Regelbereich: 8-24V DC
Material: Kunststoff;Keramik;
PUM Alphacool VPP655 - OT12 (G1/2" Außengewinde)
€99.98 *
PUM Alphacool VPP655 - T12 (1/2" Schlauchanschluss)
Alphacool VPP655 - T12 (1/2" barbed connectors)
€99.98 *
PUZ Alphacool Laing DDC-SilentBox EOL
€6.49 * €19.99 *
Alphacool Laing DDC-SilentBox bottom
€2.09 * €4.59 *
€1.88 *
€3.98 *
€99.98 *
ANF Alphacool HF Verlängerung G1/4 auf G1/4 20mm - Deep Black
Alphacool HF extension G1/4 to G1/4 20mm - Deep Black
€2.78 *
RAD Alphacool NexXxoS XT45 Full Copper 480mm Radiator
Alphacool NexXxoS XT45 Full Copper 480mm radiator
€99.98 * €126.98 *
PUM Alphacool VPP655 - Single Edition
Alphacool VPP655 - single edition
€69.98 * €79.98 *
WAK Alphacool ES NV A100 80GB PCIe
€299.98 *
Alphacool Core 1 Aurora Black
€119.98 *
AGB Alphacool Core Distro Plate 360 Rechts mit VPP Pumpe
Alphacool Core Distro Plate 360 right with VPP Apex pump
€249.98 *
WAC Alphacool Eisblock XPX Aurora Edge - Full Brass Chrome Digital RGB
€79.98 * €109.98 *
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
Alphacool Eiszapfen angled adaptor 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Deep Black
Content 4 Stück (€7.25 * / 1 Stück)
€28.98 *
Alphacool Eiszapfen 13mm HardTube compression fitting 90° rotatable G1/4 for Acryl/Brass tubes - 4pcs Set Deep Black
Content 4 Stück (€11.75 * / 1 Stück)
€46.99 *
WAK Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 Reference EOL
€49.98 * €86.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz
Alphacool Eiszapfen temperature sensor flat G1/4 - Black
RAD Alphacool NexXxoS HPE-45 Full Copper 140mm Radiator
€79.98 * €89.98 *
AGB Alphacool Core 200 Aurora Ausgleichsbehälter D5/VPP Acetal/Acryl
Alphacool Core 200 Aurora reservoir D5/VPP Acetal/Acryl
€49.98 * €101.13 *
€45.98 * €67.21 *
ANK Alphacool ES Distro Plate Parallel C5
€64.98 *
€65.99 * €89.23 *
S16 Alphacool EPDM Tube 16/10 - Black 50m Rolle
Content 5000 Zentimeter (€5.60 * / 100 Zentimeter)
€279.98 *
RAD Alphacool NexXxoS HPE-45 Full Copper 420mm Radiator
€139.98 *
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG
Alphacool ES Big Inline particle filter 2x G1/4" IG
€29.98 *
€44.98 *
Radiator fan mounting screw M3 x 15 mm - 4 pcs
€3.48 *
L14 Alphacool Rise Aurora 140mm Lüfter (140x140x25mm) EOL
Alphacool Rise Aurora 140mm Fan (140x140x25mm)
€15.98 * €22.98 *
