Alphacool Aurora HardTube LED Ring 16mm Deep Black - Digital RGB
- Article no.: 15367
- EAN: 4250197153676
- Weight: 0,018 kg
The new Aurora HardTube LED rings with addressable RGB connection offer you the best modding options to control and stage your system like a pro.
Optics at its finest
The new aRGB technology gives you the option to illuminate your entire system with different color modes. This makes your gaming system a real eye-catcher at any LAN party or simply at home.
Alphacool offers compatibility
With the new LED rings from Alphacool you can illuminate all hard tubes or hoses with an outer diameter of 13mm or 16mm and thus equip a variety of different systems, just as you want. The power connection is made via a 3-pin JST connector. For direct connection to a mainboard, a 3-pin JST to 3-pin aRGB adapter is required.
Technical data:
- Inner diameter: 16 mm
- Outer diameter: 25 mm
- Case length: 20 mm
- LEDs: Digital addressable RGB LEDs
- Connector: 3-pin
- Cable length: 75 cm
