Alphacool Eisblock Aurora Geforce RTX 4070 TI ROG Strix with Backplate
- Article no.: 13749
- EAN: 4250197137492
- Weight: 1,752 kg
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
The Aurora design of the Geforce RTX 40XX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
- Asus ROG Strix GeForce RTX 4070 Ti OC, ROG-STRIX-RTX4070TI-O12G-GAMING (90YV0II0-M0NA00)
- Asus ROG Strix GeForce RTX 4070 Ti, ROG-STRIX-RTX4070TI-12G-GAMING (90YV0II1-M0NA00)
- Asus ROG Strix GeForce RTX 4070 Ti SUPER OC, ROG-STRIX-RTX4070TIS-O16G-GAMING, 16GB GDDR6X (90YV0KG0-M0NA00)
- Asus ROG Strix GeForce RTX 4070 Ti SUPER, ROG-STRIX-RTX4070TIS-16G-GAMING, 16GB GDDR6X (90YV0KG1-M0NA00)
| Technical data | |
| Dimensions (L x W x H) | 240 x 156,90 x 34,70mm |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 14 |
| Pressure tested | 0,8 bar |
| Dimensions (L x W x H) | 240,00 x 132,40 x 6mm |
| Material | aluminium |
| Color | black |
Warranty: 2 years
Delivery date: in 2 - 3 days
Delivery date: in 11 - 12 weeks
