Alphacool Eiszapfen 16mm HardTube screw-on nozzle 90° L-connector acrylic brass tubes - Chrome
  • 17445
  • 4250197174459
  • 0,088 kg
€11.98 *
S16 Alphacool HardTube 16/11mm borosilicate glass 40cm
€11.98*
S16 Alphacool Ice Tube 16/13mm Acrylic (PMMA) HardTube Satin 80cm - Set of 4 (320cm)
€38.98*
S16 Alphacool Ice Tube 16/13mm PETG HardTube 80cm - Set of 4 (320cm)
€26.98*
ANS Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° L-connector acrylic brass tubes - Deep Black
€8.98*
With the Alphacool icicle you can connect your hard tubes at a perfect 90° angle. The hard tube... more
With the Alphacool icicle you can connect your hard tubes at a perfect 90° angle. The hard tube is screwed tightly with the union nut, seals immediately and can be easily removed again with one hand.
Technical details:
  • Width: 38mm
  • Length: 38mm
  • Material: Brass
  • Colour: Deep Black
€38.98 *
€1.98 *
€26.98 *
€28.98 *
€41.98 * €59.98 *
