  • 12955
  • 4250197129558
  • 0,569 kg
€36.98 * €39.98 * (7.5% Saved)
€6.98*
ANS Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 - Deep Black
€9.98*
12879 Alphacool Eisfrost Xtreme liquid metall paste 1g
€6.99*
€15.98*
With the Eisblock Aurora XP³ light you get a very compact CPU water block for all current... more
With the Eisblock Aurora XP³ light you get a very compact CPU water block for all current mainstream sockets from AMD and Intel. It offers the typical high Alphacool quality paired with excellent performance at a fantastic price.
High cooling capacity!
The cooling plate has been optimised to give the best performance for the price point. The nickel-plated copper radiator bottom has a surface area of 56 x 56 mm with a cross-slot structure and only 0.4 x 1 mm thick pins through which the water can flow. Due to the extremely large cooling surface, the water can effectively absorb the heat from the radiator bottom and remove it from the CPU area. The pin area is about 27.6 x 37.6 mm ensuring that most mainstream CPUs are covered completely which guarantees high cooling performance. The new multiple slotted nozzle plate was developed especially for this cooler to achieve a perfect interplay of water flow and inflow of the base plate. Only the combination of all these little things ensures the high performance.
Let’s Have All the Colours!
9 digital RGB LEDs in a U-shaped configuration are inside the Alphacool Eisblock Aurora XP³. This ensures penetrating and extensive lighting. With the right addressable Digital RGB Controller each LED can be controlled individually. All known effects and colours can be displayed as desired. The connection is made via the usual 3-pin 5V connector. The outgoing cable has an integrated Y-adapter so you can easily and quickly connect several Aurora products together. This means that you don’t have to buy any special cables and means that you can create a cleaner look as you don’t have as many cables.
Quick assembly!
The mounting bracket is simply put over the CPU cooler. All mounting screws can be pre-assembled onto this Then you can simply screw it down. A well-illustrated manual with large render graphics is included so that the installation is easy to understand.
The Eisblock Aurora XP³ Light offers not only a visual masterpiece with an extensive addressable digital RGB LED lighting, it also offers high performance thanks to the many small technical details.
Intel: 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066 / 1851
AMD: AM5 / AM4 / AM3+ / AM3 / AM2
L x W x H73 x 63 x 21mm
Weigth136g
Max working temperature60°C
Material cooling platenickel plated copper
Material cooler topAcryl
Connections2 x G1/4"
Pressure tested0,8Bar
Power connector Digital RGB3-Pin 5V
€1.78 *
Delivery date: in 5 - 6 days
€20.98 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Blue transparent 3m (9.8ft) Retailbox 300cm
Alphacool Eiszapfen 14mm HardTube screw-on nozzle G1/4 - Deep Black Sixpack
€34.98 *
