Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800XT/6900XT Nitro+ with backplate
  • 14424
  • 4250197144247
  • 5,06 kg
€149.98 * €269.98 * (44.45% Saved)
ROH Alphacool Eisbaer TPV Extension Set (hose and connections)
€15.39*
ROH Alphacool Eisbaer TPV Extension Set 90° (hose and connections)
€18.49*
PUM Alphacool Eisstation DC80 - AIO Power Unit
€69.98*
WZS Alphacool Apex filling funnel G1/4"
€7.98*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
The Eiswolf 2 cooler has a digital RGB LED lighting, also called addressable RGB LEDs. They run along the entire back of the graphics card cooler and provide complete illumination of the water cooler. The pump unit is more discreet and offers a green glowing logo for Nvidia and a red glowing logo for AMD cards. The name "Eiswolf" on the pump unit remains unlit, discreetly in the background. The fan used is the Aurora Rise with 120mm. Due to the special blade design, the fan is extremely quiet and the addressable RGB LEDs provide brilliant illumination. The Alphacool Aurora Rise fan convinces with a max. statistical pressure of 3.17mm/H2O and offers a max. air flow of 119.8m3/h. The PWM control allows the fan to be controlled over a wide speed range. In addition, it offers a zero control. It can therefore be regulated down to 0 rpm and then starts with approx. 350 rpm.
NexXxoS Radiator
Technical note!
- Sapphire Nitro+ Radeon RX 6800 XT SE, 16GB GDDR6 (11304-01-20G)
- Sapphire Nitro+ Radeon RX 6800 XT, 16GB GDDR6 (11304-02-20G)
- Sapphire Nitro+ Radeon RX 6900 XT, 16GB GDDR6 (11308-01-20G)
Data radiator
L x W x H395 x 124 x 30mm (+/- 3%)
Material cooling finsCopper
Material chambersCopper
Material threadsBrass
G 1/4“ threads2 x for tubes (+ 1x Fillport G1/4“)
For fan size120 mm
Possible fan assembly3 x one-sided / 6 x both-sided
Data cooler and pump
L x W x H260 x 142,5 x 46mm
Material cooler bottomChrome plated copper
Material cooler topPMMA
Threads2 x G1/4“
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5V DC
Power consumption3.2W
MTBF50.000 h
Data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 C° / +90 °C
Data quick fasteners
L x D95 x 27 mm
MaterialNylon
For tube size12,7 / 7,6 mm
ColorBlack
Data fittings
L x D straight fitting24 x 18 mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17 mm
Quantity 90° fittings2x
Material fittingsBrass
Data tube
Length50 cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12,7 / 7,6 mm
Hardness grade35 Shore-A to 50 Shore-D
Working temperature-50 to +155 °C
Data fan
Speed0 - 2500 RPM
Static pressure3,17 mm H2O
Air flow rate119,8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Dimensions120 x 120 x 25 mm
Net weight187 g
Max working temperature60 °C
Manufacturer: Alphacool
Radiator dimensions: 395 x 124 x 30mm
Radiator thickness: 29 - 39mm
Radiator size: 360mm
Hose dimensions: 12,7/7,6mm
Base: AMD Radeon RX
Prefilled: Yes
