Alphacool Eiswolf 2 AIO - 360mm RTX 3090TI Suprim X with Backplate
  • 14477
  • 4250197144773
  • 5,34 kg
€169.98 * €269.98 * (37.04% Saved)
ROH Alphacool Eisbaer TPV Extension Set (hose and connections)
€16.98*
11951 Alphacool Aurora vertical GPU mount with riser cable
€79.98*
14466 Alphacool Filling bottle Core 500ml
€5.99*
13084 Alphacool Eisblock XPX Pro Aurora - Full Brass Black Digital RGB
€89.98*
13096 Alphacool Apex Thermal grease 20g
€46.98*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based on the Alphacool Eisblock Aurora GPX water block, a pump unit and a 360mm NexXxoS ST30 full copper radiator. The latter is equipped with the Alphacool Aurora Rise Digital RGB fans.
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- MSI GeForce RTX 3090 Ti Gaming Trio 24G, 24GB GDDR6X (V509-029R)
- MSI GeForce RTX 3090 Ti Gaming X Trio 24G, 24GB GDDR6X (V509-014R)
- MSI GeForce RTX 3090 Ti Suprim 24G, 24GB GDDR6X
- MSI GeForce RTX 3090 Ti Suprim X 24G, 24GB GDDR6X (V509-003R)
Technical data radiator
L x W x H395 x 124 x 30mm (+/- 3%)
Material cooling fins, chambers & channelsCopper
Material threadsBrass
G 1/4“ threads2 x for tubes (+ 1x Fillport G1/4“)
For fan size120 mm
Possible fan assembly3 x one-sided / 6 x both-sided
Technical data cooler and pump
L x W x H265,8 x 162,5 x 46mm
Material cooler bottomChrome plated copper
Material cooler topacrylic
Threads2 x G1/4“
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5V DC
Power consumption3.2W
MTBF50.000 h
Technical data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 C° / +90 °C
Technical data quick fasteners
L x D95 x 27mm
MaterialNylon
For tube size12,7 / 7,6mm
ColorBlack
Technical data fittings
L x D straight fitting24 x 18mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17mm
Quantity 90° fittings2x
Material fittingsBrass
Technical data tube
Length50cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12,7 / 7,6mm
Hardness grade35 Shore-A to 50 Shore-D
Working temperature-50 to +155 °C
Technical data fan
Speed0 - 2500 RPM
Static pressure3,17 mm H2O
Air flow rate119,8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Dimensions120 x 120 x 25mm
Net weight187g
Max working temperature60°C
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 100x100x1,5mm
Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1,5mm
Content 100 cm² (€1.20 * / 1 cm²)
€119.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 100x100x1mm
Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1mm
Content 100 cm² (€0.75 * / 1 cm²)
€74.98 *
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1mm
Content 100 cm² (€1.00 * / 1 cm²)
€99.98 *
Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.50 * / 1 cm²)
€49.98 *
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.37 * / 1 cm²)
€36.99 *
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
Content 100 cm² (€0.22 * / 1 cm²)
€21.98 *
Alphacool y-splitter 3-Pin to 3x 3-Pin 30cm
€2.98 *
€2.48 *
€5.99 *
Delivery date: in 2 - 3 weeks
ANF Alphacool HF Verlängerung G1/4 auf G1/4 - Deep Black PHT EOL
Alphacool HF extension G1/4 to G1/4 - Deep Black
€2.78 *
Delivery date: in 5 - 6 weeks
