Alphacool Eisbaer Socket 775,1150,1151,1155,1156,1366,2011,2066 bracket with backplate and
WACZ Alphacool Eisbaer Socket 775,1150,1151,1155,1156,1366,2011,2066,1700,1851 Halterung mit Backplate und Schrauben
  • 12567
  • 4250197125673
  • 0,09 kg
Alphacool Eisbaer Intel bracket as a spare part. This bracket is the same as the one included... more
This bracket is the same as the one included in the original box of the Alphacool Eisbaer.
Intel 1150/1151/1155/1156, Intel 1366, Intel 2011, Intel 775, Intel 2066, Intel 2011-3,
Intel 1700/1851
Note:
If the bracket is to be used exclusively for the Intel 1700/1851 socket, we recommend the Alphacool Core Backplate XPX/Eisbaer LGA 115X/1200/1700/1851 Metal
  • 1x Alphacool Eisbaer Intel bracket with backplate and screws
Alphacool Eisbaer screw kit M3 x 5/M3 x 30mm
Content 18 Stück (€0.33 * / 1 Stück)
€5.98 *
€6.49 * €8.98 *
WAC Alphacool Core 1 Silver
€26.98 *
Alphacool NexXxoS ST30 Full Copper 240mm radiator
€51.98 *
Alphacool Core double sided adhesive thermal pad 100x100x0.25mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.99 *
20%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
Content 16 cm² (€0.40 * / 1 cm²)
€6.39 * €7.98 *
€2.78 *
