Alphacool ES Chiller 1000
  • 13070
  • 4250197130707
  • 18,19 kg
€578.98 * €699.98 * (17.29% Saved)
18599 Alphacool ES Liquid GL50 (-40°C) 1000ml
€19.98*
€79.98*
13736 Alphacool ES 19" Open Frame Serverrack 15U Adjustable Depth
€259.98*
13737 Alphacool ES 19" Open Frame Serverrack 18U Adjustable Depth
€274.99*
13738 Alphacool ES 19" Open Frame Serverrack 25U Adjustable Depth
€289.98*
The Alphacool ES Chiller 1000 is a compressor cooling system with a maximum cooling capacity of... more
The Alphacool ES Chiller 1000 is a compressor cooling system with a maximum cooling capacity of 1000 watts, making it the perfect choice for cooling servers and workstation systems. Equipped with an integrated pump, the chiller takes on the task of circulating and cooling the coolant. Ensuring that the desired temperature is maintained.
All in One
The ES Chiller is equipped with a display that can be used to configure various settings, including temperature control in precise 0.3°C increments. The G1/4" connections are compatible with common connections for water cooling systems. A built-in reservoir holds a capacity of 2 liters. Thanks to the integrated pump, with a maximum delivery head of up to 10m, the chiller can be integrated directly into the cooling loop. An extra pump is not necessary. For the sake of additional protection, the chiller is equipped with overvoltage protection for the compressor and has an alarm that warns if the flow rate is too low or the temperature is too high.
The ES Chiller 1000 is a stationary appliance with a carrying handle for easy transportation.
Performance calcuation
Water outlet temperature (Fw)
C°810152025303540
factor0,690,7711,221,441,641,822
Ambient temperature (Fa)
C°1520253235404550
factor1,261,21,1110,950,870,80,72
Percentage of glycol in coolant (Fg)
%010152025303540
factor10,960,950,940,930,910,90,88
Formular: 1,08kW * Fw * Fa * Fg
Example: A chiller delivers 1.08kW cooling capacity. Water outlet temperature (Fw) is 30 C°, Ambient temperature (Fa) is 40 C° and Percentage of glycol (Fg) is 30 %.
Calculation: 1,08kW * 1,64 * 0,87 * 0,91 = 1,4kW
Dimensions (L x W x H)440 x 260 x 390 mm
Net Weight16 kg
Voltage220 V
Frequency50 Hz
Current0.4-2.68 A
Compressor Power0.44/0.46 kW
Refrigeration Capacity0.89/1.08 kW
RefrigerantR1234YF
Refrigerant Charge280 g
Precision±0.3 °C
ReducerCapillary
Pump Power0.03 kW
Reservoir Capacity2 L
Inlet / OutletG 1/4 Inner threads
max. Lift10 m
max. Flow10 L/min
ProtectionOver current protection for compressor, flow alarm, over temperature alarm
IP ratingIP44
Recommended operating temperature (in °C)5 °C to 40 °C
Recommended storage temperature (in °C)0 °C to 40 °C
€69.98 *
38%
RAK Alphacool ES Chiller 1000 ServerRack 5HE
Alphacool ES Chiller 1000 ServerRack 5U
€999.98 * €1,599.98 *
S16 Alphacool Schlauch AlphaTube TPV 16/10 - Black Matte 50m Rolle
Alphacool Tubing AlphaTube TPV 16/10 - Black Matte 50m Roll
Content 5000 Zentimeter (€5.70 * / 100 Zentimeter)
€284.98 *
