Alphacool Apex Thermal Pad Soft 16W/mk 120x20x1,5mm
  • 13490
  • 4250197134903
  • 0,05 kg
€44.98 *
Content: 24 cm² (€1.87 * / 1 cm²)
€4.28*
€69.98*
13489 Alphacool Apex Thermal Pad Soft 16W/mk 120x20x1mm
€34.97*
13493 Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1,5mm
€119.98*
Alphacool offers a wide range of thermal pads for effective heat dissipation of electric... more
Powerful!
Increased lifespan!
Versatile!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 1,5mm
Thermal Conductivity (ASTM D5470)16.6 W/mK (±10%)
Hardness (ASTM D2240)65 (Shore 00) (±5)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)5×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)5 KV/mm (±10%)
Density (ASTM D792)3.6 g/cm³ (±10%)
Elongation (ASTM D412)20%
Flame Rating (UL 94)V-0
Colordark grey
€0.98 *
WÄM Alphacool Wärmeleitklebepad doppelseitig 120x20x0,5mm EOL
Alphacool thermal adhesive pad double-sided 120x20x0.5mm
Content 24 cm² (€0.10 * / 1 cm²)
€2.28 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x1mm
Content 24 cm² (€1.46 * / 1 cm²)
€34.97 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x0,5mm
Alphacool Apex Thermal Pad Soft 16W/mk 120x20x0,5mm
Content 24 cm² (€0.62 * / 1 cm²)
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
Content 16 cm² (€0.50 * / 1 cm²)
WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 40x40x1mm
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1mm
Content 16 cm² (€0.44 * / 1 cm²)
€6.99 *
€29.98 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Electric Blue (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
