Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
  • 13419
  • 4250197134194
  • 0,117 kg
€27.98 * €49.98 * (44.02% Saved)
Content: 100 cm² (€0.28 * / 1 cm²)
€4.28*
€69.98*
13416 Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
€11.78*
13424 Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
€7.68*
13427 Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
€6.99*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 3mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Elongation (ASTM D412)40%
Flame Rating (UL 94)V-0
Colorpink
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
49%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.19 * / 1 cm²)
€18.78 * €36.99 *
46%
Content 100 cm² (€0.12 * / 1 cm²)
€11.78 * €21.98 *
45%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1,5mm
€16.48 * €29.98 *
47%
€15.78 * €29.98 *
31%
€23.98 * €34.97 *
56%
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1mm
Content 100 cm² (€0.44 * / 1 cm²)
€43.98 * €99.98 *
50%
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
€1.89 *
61%
€5.78 * €14.98 *
32%
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 100x100x1,5mm
Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1,5mm
Content 100 cm² (€0.81 * / 1 cm²)
€81.28 * €119.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 120x20x0,5mm
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x0,5mm
Content 24 cm² (€0.17 * / 1 cm²)
€4.18 * €5.99 *
37%
WÄM Alphacool Apex Soft Wärmeleitpad 14W/mk 100x100x1mm
Alphacool Apex Soft Thermal Pad 14W/mk 100x100x1mm
€44.08 * €69.98 *
43%
€3.97 * €6.99 *
€6.49 * €8.98 *
Alphacool Eisblock Aurora mounting screws and springs M2x6mm
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
32%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
Content 100 cm² (€0.55 * / 1 cm²)
€54.78 * €79.98 *
€29.98 *
