Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
  • 13413
  • 4250197134132
  • 0,022 kg
€4.89 * €6.99 * (30.04% Saved)
Content: 24 cm² (€0.20 * / 1 cm²)
€4.28*
€69.98*
13403 Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1mm
€8.44*
13409 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1,5mm
€4.68*
13412 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x0,5mm
€4.18*
Erhalte 20% Rabatt auf ausgewählte Produkte. Der gewährte Rabatt ist im Warenkob sichtbar.
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 1mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
20% Cyber Monday
€0.98 *
20% Cyber Monday
€1.19 *
20% Cyber Monday
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
20% Cyber Monday
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 120x20x0,5mm
Content 24 cm² (€0.17 * / 1 cm²)
€4.18 * €5.99 *
27%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x2mm
Content 16 cm² (€0.32 * / 1 cm²)
€5.08 * €6.99 *
42%
20% Cyber Monday
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 * €11.98 *
43%
20% Cyber Monday
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1mm
Content 24 cm² (€0.24 * / 1 cm²)
€5.68 * €9.98 *
43%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x0,5mm
Content 24 cm² (€0.19 * / 1 cm²)
€4.58 * €7.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
20% Cyber Monday
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 *
20%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x0,5mm
Content 100 cm² (€0.10 * / 1 cm²)
€9.50 * €11.86 *
20% Cyber Monday
20% Cyber Monday
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 *
37%
20% Cyber Monday
WÄM Alphacool Apex Soft Wärmeleitpad 14W/mk 100x100x1mm
Alphacool Apex Soft Thermal Pad 14W/mk 100x100x1mm
Content 100 cm² (€0.44 * / 1 cm²)
€44.08 * €69.98 *
33%
€5.99 * €8.98 *
43%
€3.97 * €6.99 *
21%
€33.97 * €42.98 *
47%
20% Cyber Monday
WÄM Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 120x20x1mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1mm
Content 24 cm² (€0.15 * / 1 cm²)
€3.68 * €6.99 *
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
