Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x0.5mm - 2 pieces
- Article no.: 12461
- EAN: 4250197124614
- Weight: 0,033 kg
Fastening: | Slightly adhesive |
Thickness: | 0,5mm |
Surface dimensions: | 120 x 20mm |
Thermal conductivity: | 14W/mk |
