Alphacool Apex thermal pad Soft 16W/mk 120x20x0.5mm
- Article no.: 13488
- EAN: 4250197134880
- Weight: 0,018 kg
- Available: There are more than 5 units available
Powerful!
Increased lifespan!
Versatile!
Technical data thermal pad | |
Dimensions (L x W x H) | 120 x 20 x 0,5mm |
Thermal Conductivity (ASTM D5470) | 16.6 W/mK (±10%) |
Hardness (ASTM D2240) | 65 (Shore 00) (±5) |
Working temperature | -50 to ~150°C |
Volume Resistance (ASTM D257) | 5×10¹² Ohm-m |
Dielectric Breakdown Voltage (ASTM D149) | 5 KV/mm (±10%) |
Density (ASTM D792) | 3.6 g/cm³ (±10%) |
Elongation (ASTM D412) | 20% |
Weight Loss (ASTM E595) | less than 1% |
Flame Rating (UL 94) | V-0 |
Color | dark grey |
Thickness: | 0,5mm |
Surface dimensions: | 120 x 20mm |
Thermal conductivity: | 16W/mk |
