Alphacool NexXxoS Monsta 560mm radiator
- Article no.: 14192
- EAN: 4250197141925
- Weight: 3,313 kg
Versatility is the essence of the new NexXxos series! The radiators are available in different versions to be use with 120mm, 140mm or 180mm fans and are available in different thicknesses. The choice of 30mm, 45mm and 60mm offers the perfect radiator for every purpose. Even mounting and installation of fans and radiator grills is easy and versatile with these radiators: The M3 threads are standard in the radiator sector and available in all lengths at an affordable price.
| Technical data | |
| Dimensions (L x W x H) | 607 x 144 x 86mm |
| Quantity of cooling channels | 58 |
| Cooling channels | Copper |
| Color | black |
| Fan thread | M3 |
| Connection | 6x G1/4" |
| Slats | Copper |
| Number of fans | 4 |
| Thickness | 69 - 100mm |
| Housing | Steel |
| Manufacturer | Alphacool |
| Pressure tested | 0,8 bar |
| Fins per inch | 10 |
| Fan size | 140mm |
