Eheim 1250-790 230Volt full ceramic bearing
- Article no.: 1250740
- EAN: 4049469006785
- Weight: 1,388 kg
This high performance ceramics centrifugal pump is designed for uncompromising continuous use. It has an integrated pre-filter on the suction side to protect the pump mechanism. The base plate of the device is variable, which means there are numerous mounting options. The Eheim centrifugal pump 1250 is the ideal "motor" for your water cooling system, it is compact, tried and tested many times, quiet and works very reliably. To mount universal hose connections,
use our Eheim adapters.
This variant of the Eheim pump is delivered as a fully ceramic version with a ceramic axle and ceramic bearings. This design ensures long-term smooth running.
This pump is also suitable for use in ice bathing . With sufficient flow, it can be used in conjunction with a Hailea chiller to effectively cool the water before ice bathing. If you intend to use it for this purpose, please also order the appropriate connection adapters.
Technical data:
Pump capacity: 1200 l/h
Discharge head: 2.0 mWs
Power consumption: 28 W
Dimensions L x W x H mm: 180 x 95 x 120
Ceramic axle and ceramic bearing
EHEIM No.: 1250-790
Attention! This pump is delivered without accessories as shown in the picture!
Delivery date: in 2 - 3 days
Delivery date: in 3 - 4 days
Delivery date: in 2 - 3 weeks
