Alphacool VPP Apex Pump - G1/4 inner thread including Eisdecke D5 - Acryl V.3
  • 13306
  • 4250197133067
  • 0,738 kg
€83.98 *
The Alphacool Apex VPP is a powerful pump. Via the 4-pin fan connector, the speed of the pump... more
The Alphacool Apex VPP is a powerful pump. Via the 4-pin fan connector, the speed of the pump can be read and controlled via PWM signal. The Apex VPP is supplied with power via the SATA connector. In this version, it is supplied with the Eisdecke.
Technical data pump
Dimensions (L x W x H)65 x 65 x 41mm
Material pump coveraluminium
Material axleceramics
Connections4-Pin PWM | SATA
Cable lengths4-Pin PWM - 48cm | SATA - 48cm
Starting voltage12V DC
Maximum pumping head4,25m
Maximum flow rate340L/h
Weight276g
Technical data Eisdecke
Dimensions (L x W x H)80 x 80 x 40mm
imensions with stands (L x W x H)83 x 80 x 87mm
MaterialAcrylic
Threads5x 1/4" Gewinde
Colortransparent
11%
€15.98 * €17.98 *
€28.98 *
Delivery date: in 6 - 7 weeks
WAC Alphacool Core 1 Silver
€10.98 *
€34.98 *
