Stromversorgungskupplung für 4Pol
ZK Stromversorgungskupplung für 4Pol
  • ZK
  • 4049469057275
  • 0,02 kg
€1.69 *
For our handy DIY customers: 4-Pin Molex coupling. This coupling... more
This coupling can be used for replacement of defective old couplings. It can also be used to create custom connectors and adaptors without a great deal of work. If one wishes to optimize both optics and Airflow in a system by using custom cable length, there is no way around these DIY couplings.
The couplings also give the possibility to lower the supply voltage for e.g. fans by switching the connector pins down to 7V or even 5V to make the system more quiet-running.
The installation is quick and easy: The coupling is shipped in two parts. One is the plastic coupling itself and the other are the metal connection pins. Simply insert a bared cable into the metal pin and fixate it by closing the pin's opening with pliers. Then the pin can simply be pushed into the plastic coupling where it will lock in place.
Extent of delivery:
4x Metal pins
1x Plastic coupling
ZK Stromversorgungsstecker für 4Pin Molex
€1.69 *
KAB Alphacool Eiskamm X4 - 3mm clear - 4 Stück EOL
Alphacool Eiskamm X4 - 3mm clear - 4 pcs
Content 4 Stück (€0.50 * / 1 Stück)
€1.99 * €3.89 *
Alphacool Eiskamm X6 - 3mm clear - 4 pcs
€1.99 * €3.89 *
Alphacool Eiskamm X12 - 3mm clear - 4 pcs
€1.19 *
€1.69 *
WZS Alphacool Molex Extractor Kit Pro - Black
€24.98 *
Hint!
ZK Phobya PSU Power Connector Pin Stecker - 20 Stück EOL
Content 20 Stück (€0.12 * / 1 Stück)
€2.48 *
ZK Phobya PSU Power Connector Pin Buchse - 20 Stück
€2.48 *
Alphacool y-splitter 3-Pin to 4x 3-Pin 15cm
Content 15 Zentimeter (€33.20 * / 100 Zentimeter)
€4.98 *
Alphacool Eiszapfen 13/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
€33.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - chrom
Alphacool Eiszapfen temperature sensor flat G1/4 - chrom
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG
Alphacool ES Big Inline particle filter 2x G1/4" IG
€29.98 *
ANK Alphacool HF Schnellverschlusskupplungsset G1/4 AG/AG
Alphacool HF quick release connector kit G1/4 OT/OT
€11.98 *
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Black (Paracord 550 Typ 3) 330cm
€1.98 * €4.47 *
KAB Alphacool Eiskamm Alu X6 - 4mm black - 4 Stück EOL
Alphacool Eiskamm Alu X6 - 4mm black - 4 pcs
Content 4 Stück (€0.80 * / 1 Stück)
€3.19 * €5.94 *
KAB Alphacool Eiskamm Alu X4 - 4mm black - 4 Stück EOL
Alphacool Eiskamm Alu X4 - 4mm black - 4 pcs
€3.19 * €5.02 *
KAB Alphacool Eiskamm X24 - 3mm black - 2 Stück EOL
Alphacool Eiskamm X24 - 3mm black - 2 pcs
Content 2 Stück (€1.10 * / 1 Stück)
€2.19 * €3.99 *
KAB Alphacool Eiskamm X14 - 3mm black - 4 Stück EOL
Alphacool Eiskamm X14 - 3mm black - 4 pcs
€3.19 * €5.02 *
ANK Alphacool HF Schnellverschlusskupplungsset 11/8mm - Black
Alphacool HF quick release connector kit 11/8mm - black
LK Phobya 4Pin PWM Stecker auf Stecker - Schwarz 30cm
Content 30 Zentimeter (€11.60 * / 100 Zentimeter)
€3.48 *
€74.98 * €86.73 *
ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 60cm - Schwarz
Content 60 Zentimeter (€7.47 * / 100 Zentimeter)
€4.48 *
ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 30cm - Schwarz
€4.48 *
Hint!
ZK Phobya Fan Power Connector Pin Buchse - 20 Stück EOL
€2.48 *
KAB Phobya 4Pin Molex Stromverlängerung - Schwarz 30cm
€4.48 *
€29.98 *
LZ Lüftergitter für Axiallüfter für 140mm schwarz
€2.79 *
Hint!
LK adapter 4Pin (12V) to 3Pin (7V)
€1.19 * €2.09 *
WZS Befüllungshilfe - Kunstofftrichter
€2.59 *
