Alphacool Ice Comb X4 - 3mm clear - 4 pieces
  • 24742
  • 4250197247429
  • 0,001 kg
€0.99 * €3.89 * (74.55% Saved)
What is that?
Highlights
  • Nylon is flexible and cannot break
  • Easy installation without modifications
  • Simple and clean laying of cables
  • Material: Polyester
  • Variant: X4 Flat
  • Dimensions: 10 x 8 x 2mm
  • Color: CLear
Scope of delivery
  • Alphacool Ice Comb X4 Flat - 3mm clear - 4 pieces
Datasheet
Assembly instructions
57%
Alphacool Laing DDC-SilentBox bottom
€1.99 * €4.59 *
62%
€0.99 * €2.59 *
83%
€1.49 * €8.98 *
75%
KAB Alphacool Eiskamm X24 - 3mm clear - 2 Stück EOL
Alphacool Ice Comb X24 - 3mm clear - 2 pieces
€0.99 * €3.89 *
75%
€0.99 * €3.89 *
75%
Alphacool Eiskamm X4 Flat - 3mm clear - 4 pieces
€0.99 * €3.89 *
67%
Alphacool Eiskamm X5 Flat - 3mm clear - 4 pieces
€0.99 * €2.99 *
78%
€0.99 * €4.49 *
€0.99 *
20%
Content 2 Stück (€12.80 * / 1 Stück)
€25.59 * €31.98 *
Alphacool Eiskamm Alu X6 - 4mm silver - 4 pieces
€0.99 * €5.02 *
€0.99 * €5.02 *
75%
Alphacool Eiskamm X4 Flat - 3mm black - 4 pieces
€0.99 * €3.99 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 60cm white
Content 60 Zentimeter (€5.82 * / 100 Zentimeter)
€3.49 * €4.97 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 30cm white
Content 30 Zentimeter (€8.83 * / 100 Zentimeter)
€2.65 * €3.78 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 60cm white
Content 60 Zentimeter (€4.55 * / 100 Zentimeter)
€2.73 * €3.88 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 30cm white
Content 30 Zentimeter (€6.97 * / 100 Zentimeter)
€2.09 * €2.98 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 15cm white
Content 15 Zentimeter (€12.07 * / 100 Zentimeter)
€1.81 * €2.58 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 60cm
€6.99 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 30cm
€5.99 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 15cm
€5.68 *
Alphacool Y-Splitter aRGB 3-Pin to 3x 3-Pin 15cm
€4.48 *
Alphacool Y-Splitter aRGB 3-Pin to 3x 3-Pin 60cm
€5.99 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 60cm
€4.68 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 30cm
€3.97 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 15cm
€3.47 *
€2.98 *
€2.78 *
€2.58 *
€1.68 *
€1.48 *
Alphacool Y-Splitter 3-Pin to 4x 3-Pin 30cm
Content 30 Zentimeter (€8.37 * / 100 Zentimeter)
€2.51 * €3.58 *
Alphacool fan cable 3-Pin to 3-Pin extension 60cm
Content 60 Zentimeter (€2.90 * / 100 Zentimeter)
€1.74 * €2.48 *
Alphacool fan cable 3-Pin to 3-Pin extension 30cm
Content 30 Zentimeter (€5.30 * / 100 Zentimeter)
€1.59 * €2.28 *
Alphacool fan cable 3-Pin to 3-Pin extension 15cm
Content 15 Zentimeter (€9.27 * / 100 Zentimeter)
€1.39 * €1.98 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 30cm
Content 30 Zentimeter (€9.97 * / 100 Zentimeter)
€2.99 * €4.28 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 15cm
Content 15 Zentimeter (€16.20 * / 100 Zentimeter)
€2.43 * €3.47 *
Content 60 Zentimeter (€5.12 * / 100 Zentimeter)
€3.07 * €4.38 *
