  • 24784
  • 4250197247849
  • 0,003 kg
€0.99 * €4.89 * (79.75% Saved)
Content: 2 Stück (€0.50 * / 1 Stück)
What is that?
Highlights
  • Made of aluminum
  • More stable than acrylic
  • For all common cable types
  • Four different colors
  • Material: aluminum
  • Variant: X24
  • Dimensions: 53.4 x 9.5 x 2.5mm
  • Color: Red
Scope of delivery
  • Alphacool Eiskamm Alu X24 - 4mm red - 2 pieces
Datasheet
Assembly instructions
90%
€0.99 * €9.94 *
86%
€0.99 * €6.96 *
78%
Alphacool Eiskamm Alu X4 Flat - 4mm red - 4 pieces
€0.99 * €4.59 *
€0.99 * €5.02 *
Alphacool Eiskamm Alu X4 - 4mm red - 4 pieces
€0.99 * €4.89 *
86%
Alphacool Eiskamm Alu X8 - 4mm silver - 4 pieces
€0.99 * €6.96 *
€0.99 * €4.89 *
Alphacool Eiskamm Alu X5 Flat - 4mm red - 4 pieces
€0.99 * €4.89 *
€0.99 * €5.02 *
90%
Alphacool Eiskamm Alu X16 - 4mm silver - 4 pieces
€0.99 * €9.94 *
€0.99 * €5.02 *
€0.99 * €5.02 *
75%
€0.99 * €3.99 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Imperial Red (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Electric Blue (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Colonial Blue (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Acid Purple (Paracord 550 Typ 3) 330cm EOL
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Acid Purple (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
90%
Alphacool Eiskamm Alu X16 - 4mm blue - 4 pieces
€0.99 * €9.59 *
85%
Alphacool Eiskamm Alu X8 - 4mm blue - 4 pieces
€0.99 * €6.59 *
89%
Alphacool Eiskamm Alu X14 - 4mm red - 4 pieces
€0.99 * €8.89 *
85%
Alphacool Eiskamm Alu X12 - 4mm silver - 4 pieces
€0.99 * €6.56 *
€0.99 * €5.02 *
42%
Hint!
€5.99 *
WAC Alphacool Core 1 Silver
Alphacool y-splitter 3-Pin to 4x 3-Pin 30cm
Content 30 Zentimeter (€11.93 * / 100 Zentimeter)
€3.58 *
Alphacool Y-splitter 3-Pin to 3x 3-Pin 60cm
Content 60 Zentimeter (€6.62 * / 100 Zentimeter)
€3.97 *
€2.28 *
Alphacool fan cable 3-Pin to 3-Pin extension PWM 60cm
€2.48 *
€2.28 *
52%
Hint!
€4.80 * €9.98 *
€34.98 *
