Alphacool Eiskamm X16 - 3mm clear - 4 pcs
  • 24747
  • 4250197247474
  • 0,002 kg
€1.99 * €4.89 * (59.3% Saved)
Content: 4 Stück (€0.50 * / 1 Stück)
What is it? The Alphacool Eiskamm is the perfect cable comb for laying cables neatly and... more
What is it?
The Alphacool Eiskamm is the perfect cable comb for laying cables neatly and getting the best look for your system.
Highlights
  • Nylon is flexible and won't break
  • Simple installation, no rebuilding required
  • Clean, simple cable organisation
The Alphacool Eiskamm is the simplest solution for getting your cable bundles in order. With the outside-opening Eiskamm cable combs, you can smoothly and easily press cables into the combs and lay them neatly. There's no easier way to get your cables into their proper positions. Since they're made of nylon instead of acrylic, the Eiskamm combs are extremely flexible and won't break in any type of normal usage.
Technical Specifications
  • Material: Nylon
  • Version: X16 Flat
  • Dimensions: 34.5 x 8 x 2mm
  • Colour: Clear
Scope of Delivery
  • Alphacool Eiskamm X16 Flat - 3mm clear - 4 pieces
Datasheet
Installation Instructions
75%
KAB Alphacool Eiskamm X4 - 3mm clear - 4 Stück EOL
Alphacool Ice Comb X4 - 3mm clear - 4 pieces
€0.99 * €3.89 *
75%
€0.99 * €3.89 *
€0.99 *
75%
KAB Alphacool Eiskamm X24 - 3mm clear - 2 Stück EOL
Alphacool Ice Comb X24 - 3mm clear - 2 pieces
€0.99 * €3.89 *
90%
€0.99 * €9.94 *
Alphacool Core thermal pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.62 * / 1 cm²)
Alphacool Y-Splitter 3-Pin to 4x 3-Pin 30cm
Content 30 Zentimeter (€8.37 * / 100 Zentimeter)
€2.51 * €3.58 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 15cm
Content 15 Zentimeter (€16.20 * / 100 Zentimeter)
€2.43 * €3.47 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 15cm
Content 15 Zentimeter (€13.00 * / 100 Zentimeter)
€1.95 * €2.78 *
€6.99 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
86%
Alphacool Eiskamm Alu X8 - 4mm silver - 4 pieces
€0.99 * €6.96 *
75%
€0.99 * €3.99 *
€0.99 * €5.02 *
75%
Alphacool Eiskamm X4 Flat - 3mm clear - 4 pieces
€0.99 * €3.89 *
€0.99 *
75%
€0.99 * €3.89 *
Laing DDC pump 12V DDC 4.2 PWM
€74.98 * €101.13 *
LK Adapter 3Pin (12V) auf 4Pin Molex (12V)
€1.79 *
