Alphacool Aurora HardTube LED Ring 16mm Chrome - RGB
  • 15354
  • 4250197153546
  • 0,018 kg
€8.48 *
€19.98*
S16 Alphacool Ice Tube 16/13mm PETG HardTube 80cm - Set of 4 (320cm)
€26.98*
S16 Alphacool HardTube 16/13mm 90° acrylic (PMMA) 10/30cm
€9.98*
The Alphacool Aurora HardTube RGB LED Ring is the perfect solution for illuminating the... more
The Alphacool Aurora HardTube RGB LED Ring is the perfect solution for illuminating the HardTubes or hoses of the water cooling system. To do this, the Aurora HardTube RGB LED Ring simply has to be pushed over the hose or the HardTube. The connection is made via a 4-pin male RGB connector. The ring itself is made of pure brass. Inside the ring there are 3 RGB LEDs and two O-rings. The O-rings serve to hold the Aurora HardTube RGB LED Ring in its desired position and to prevent scratches when slipping it onto the HardTubes.
This opens up completely new lighting options for your own water cooling system. The classic RGB LED strips or RGB fans can be wonderfully complemented to achieve a harmonious and impressive look. If you also use the colorful Alphacool ice water liquids for water cooling, there are hardly any restrictions when it comes to the visual design of the water cooling system.
The Alphacool Aurora HardTube RGB LED rings are compatible with all common RGB controllers. Of course, they can also be operated with any motherboard. They are fully compatible with: ASUS ROG Aura Sync, ASRock RGB LED, MSI Mystic Light and GIGABYTE RGB Fusion. Depending on the connection, a suitable adapter may be required. The simplest option is to use the Alphacool Aurora RGB controller.
  • Size: for 16mm HardTubes
  • Dimensions (DxH): 25 x 20 mm
  • Housing: Plastic Chrome
  • LED color: RGB
  • Cable: RGB Male connector 30 cm
Scope of delivery
  • 1x Alphacool Aurora HardTube LED Ring 16mm Chrome - RGB
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
€26.98 *
€28.98 *
€3.18 *
€4.38 *
€1.98 *
17%
