Alphacool NexXxos GPX Pro Solo with Backplate - Black
- Article no.: WAG
- EAN: 4250197114271
- Weight: 0,608 kg
With the new NexXxoS GPX coolers, Alphacool is once again going one step ahead! This new cooling concept offers optimal performance and quality in one for little money!
Own cycle
Alphacool has succeeded in creating what is probably the smallest, most powerful water cooler in the world with its own circuit. The powerful pump, which can easily handle a cooling circuit with an additional CPU and a radiator, is integrated into the GPX Pro Solo and is therefore inconspicuous.
Alphacool uses a completely new design for the pump to minimize pump noise and increase performance. The suction pump is born. The suction principle creates less turbulence in the water for a more even flow. This makes the pump almost inaudible. A first on the AiO market.
function
The GPU is actively cooled by a new, sophisticated injection technology. ((All other chips are sufficiently cooled by the passive cooler in which the water cooler for the GPU is enclosed.) In conjunction with a GPX upgrade kit))
Phillips structure
The cross-slot technology in the base plate, which was patented for the Alphacool NexXxoS XP in 2004, has been further developed. The fins and channel structure have been further refined. The remaining pins are 0.5 x 0.5mm in size and 2.5mm high. This enables a very large and rapid heat transfer from the copper to the cooling medium.
SLI operation
Thanks to the outward-facing inlet and outlet, these coolers can also be used in SLI mode without much effort. Up to four graphics cards can also be connected to the Alphacool GPX SLI connector.
Back plate
The scope of delivery now always includes a backplate which cools the back of the GPU with small passive cooling fins, giving the graphics card a perfect impression and protecting it at the same time.
Delivery without graphics card
Compatible
- to all Alphacool Eiswolf GPX Pro's
Scope of delivery
- 1x GPX Pro Solo cooler with integrated pump
- 1x back plate
- Thermal paste
- Mounting material
The assembly instructions are available for download here
Please click here to see the hole dimensions!
Anschluss: | 2x G1/4" |
SLI kompatibel: | Nein |
Kühlertyp: | Chipkühler |
Hardware Hersteller: | AMD, NVIDIA |
Material Deckel: | Kohlefaser |
