Alphacool Core Geforce RTX 5080 Reference with backplate
  • 10248
  • 4250197102483
  • 1,18 kg
€199.98 *
€19.98*
€35.98*
€33.98*
€119.98*
- Inno3D GeForce RTX™ 5070 Ti iCHILL X3 (C507T3-16D7X-176069H)
- Inno3D GeForce RTX™ 5070 Ti X3 (N507T3-16D7-176068N)
- Inno3D GeForce RTX™ 5070 Ti X3 OC (N507T3-16D7X-176068N)
- Inno3D GeForce RTX™ 5070 Ti X3 OC WHITE (N507T3-16D7X-176068W)
- MSI GeForce RTX™ 5070 Ti 16G INSPIRE 3X OC (MS-V531 Ver:3.0)
- MSI GeForce RTX™ 5070 Ti 16G SHADOW 3X OC
- MSI GeForce RTX™ 5070 Ti 16G VENTUS 3X OC (V531-092R)
- Inno3D GeForce RTX™ 5080 iChill Frostbite (C50803-16D7X-1760FB)
- Inno3D GeForce RTX™ 5080 iChill X3 (C50803-16D7X-176069H)
- Inno3D GeForce RTX™ 5080 X3 (N50803-16D7-176068N)
- Inno3D GeForce RTX™ 5080 X3 GAMING OC (G50803-16D7X-17603930)
- Inno3D GeForce RTX™ 5080 X3 OC (N50803-16D7X-17603930)
- Inno3D GeForce RTX™ 5080 X3 OC White (N50803-16D7X-17605211)
- MSI GeForce RTX™ 5080 16G INSPIRE 3X OC (MS-V531 Ver:3.0)
- MSI GeForce RTX™ 5080 16G SHADOW 3X OC (G5080-16S3C)
- MSI GeForce RTX™ 5080 16G VENTUS 3X OC (V531-095R)
- MSI GeForce RTX™ 5080 16G VENTUS 3X OC Plus (V531-001R)
Technical data cooler
Dimensions total (L x W x H)160 x 124,07 x 34,19mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs7
Colortransparent
Technical data backplate
Dimensions (L x W x H)160 x 95,36 x 6mm
MaterialAluminium
Material base plate: Aluminum
Dimensions: 160 x 124.07 x 34.19mm
Connection: 4x G1/4"
Hardware model: RTX 5080;
€99.98 *
€33.98 *
Delivery date: in 4 - 5 days
€6.28 *
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
SZ Schlauchabschneider
hose cutter
€6.29 *
WAC Alphacool Core 1 LT Black
€74.98 *
