Alphacool Eisblock GPX SLI Upgrade Kit - Acetal
  • 12939
  • 4250197129398
  • 0,09 kg
€2.47 * €2.67 * (7.49% Saved)
Liefertermin unbekannt
WAGZ Alphacool GPX SLI Connector Dual - Acrylic - Addressable RGB - 3 PCI-E Space EOL
€23.98*
In order to use the new GPX SLI connectors on all previous models of the Eisblock GPX... more
In order to use the new GPX SLI connectors on all previous models of the Eisblock GPX 2080/2080Ti M02 series, you need this SLI adapter.
Connect your graphics cards with the new Alphacool GPX SLI connector and combine all their power! You get the perfect performance thanks to the serial water flow.
  • Dimensions (LxH): 59.8 x 15mm
  • Material: Acetal
  • 2x G1/4“ thread
Scope of delivery
  • 1x Alphacool Eisblock GPX SLI Upgrade Kit - Acetal
  • 3x M3 fixing screws
  • 2x O-rings
€69.98 *
Alphacool Eiszapfen 13/10mm screw-on nozzle G1/4 - White Sixpack
Liefertermin: in 2 - 3 Wochen
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
Content 6 Stück (€6.17 * / 1 Stück)
€36.99 *
Alphacool Eisblock Aurora mounting screws and springs M2x6mm
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
Content 330 Zentimeter (€5.75 * / 100 Zentimeter)
Content 40 Zentimeter (€19.95 * / 100 Zentimeter)
Alphacool HF screw plug G1/4 - Deep Black
€1.68 *
Liefertermin: in 8 - 9 Wochen
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
€3.48 *
