Alphacool HT 13mm HardTube screw-on nozzle G1/4 - knurled - Deep Black
  • 17189
  • 4250197171892
  • 0,026 kg
€3.68 *
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€20.98*
€25.98*
S13 Alphacool Ice Tube 13/10mm PETG HardTube 80cm - Set of 4 (320cm)
€23.98*
Alphacool has created a true masterpiece with these screw-on nozzles. These connections promise... more
Alphacool has created a true masterpiece with these screw-on nozzles. These connections promise absolute tightness and high quality.
Suitable for all hard metal pipes with an outer diameter of 13mm. On the other side of the connection is the usual ¼” thread. Available in deep black and chrome.
First, the union nut is put on the pipe, followed by a plastic washer that protects the O-ring and the thick O-ring itself. Now the pipe is simply put into the connection in which the second O-ring is already sitting, which fits very tightly against the pipe. As a last step, the union nut is pushed onto the connection and screwed on.
Due to the size, the union nut cannot be screwed on tightly enough. But this has also been thought of, as an 8 mm hexagon key can be inserted from below to hold the connection in place.
1x screw sleeve 13mm
€20.98 *
€23.98 *
€3.78 *
Delivery date: in 6 - 7 weeks
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
€25.98 *
