Alphacool Apex Stealth Metal fan 2000rpm chrome (120x120x25mm)
  • 13818
  • 4250197138185
  • 0,477 kg
  • 5
€19.98 * €29.98 * (33.36% Saved)
€115.98*
25667 Alphacool Core 10x 4-Pin PWM splitter with SATA power connector
€15.98*
18693 Alphacool y-splitter 3-Pin to 3x 3-Pin 30cm
€2.98*
13818 Alphacool Apex Stealth Metal fan 2000rpm chrome (120x120x25mm) 3x
Instead of €59.94 * (10% saved) Price for all: €53.94 *
Whisper Quiet
Powerful All-rounder
The Alphacool Apex Stealth metal fan is a true all-rounder. It sets new standards in terms of airflow and static pressure. Therefore, this fan is not only perfect for mounting on radiators, but also provides excellent airflow as a case fan. The Apex Stealth can be controlled between 400 to 2000 rpm via the 4-pin PWM connector. The startup speed is ~420 rpm. In addition, the Stealth offers Zero RPM control, which can be used to bring the fan to a complete stop.
Apex Design
Additional Features
Dimensions (L x W x H)120 x 120 x 25,5mm
Material (Frame)Die-cast zinc
Material (Impeller)Plastic
Weight320g
Speed400~2000±10% rpm
BearingHydro Dynamic Bearing
Connection4-Pin PWM
Start-up Voltage6 V DC
Rated Volt12 V DC
Power Consumption2.64 Watt
Rated Current0.20 A (0.22Max)
Air Flow47 CFM
Static Air Pressure2,09 mmH2O
Noise Level24.6 dBA
MTBF100,000h
PWM controlYes
Zero RPM controlYes
Tacho SignalYes
Auto-restartYes
Colorchrome
Warranty: 5 years
Awards & Videos
34%
Alphacool Ice Cyclone Aurora LUX Digital RGB - Kit of 3 (120x120x25mm)
Content 3 Stück (€8.66 * / 1 Stück)
€25.98 * €39.25 *
WAC Alphacool Core 1 Silver
Alphacool fan cable 4-pin to 4-pin extension 30cm
€2.28 *
Alphacool fan cable 4-pin to 4-pin extension 15cm
€1.98 *
€25.98 *
€0.99 *
Delivery date: in 7 - 8 weeks
€1.78 *
Delivery date: in 7 - 8 days
€3.47 *
€33.98 *
