Alphacool Eisbaer (Solo) - 2600rpm - black
- Article no.: 12511
- EAN: 4250197125116
- Weight: 0,542 kg
Along with the different prefilled “Eisbaer” coolers that are ready to use out of the box, the core of the “Eisbaer” is also available as a stand-alone option. With it, you can set up your system and choose which parts you want for it exactly as you wish. Thanks to the G¼” connections, nearly every standard water cooling attachment will fit. This way you can freely choose the hose thickness, colour and fluid, and design the “Eisbaer” to fit your wishes exactly.
Pump
The basis of the pumps is the Alphacool DC-LT 2, also available separately. The pump runs extremely quietly and can be regulated to between 6 and 13,5V. It can also be regulated through the motherboard. If the “Eisbaer” is being run alone, the 6V setting will still have next to no performance loss, as shown in diverse test results. The insulated pump case further perfects the noise generation and ensures that vibrations are almost completely absorbed. The smooth and shiny polished copper base of the cooler ensures optimal heat absorption and can relay the heat over the fine slit structure of the cooler to the water quickly and efficiently.
Intel 775 / 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066
AMD AM2 / AM2+ / AM3 / AM3+ / FM1 / FM2 / FM2+ / AM4 / TR4 / sTRX4 / AM5
Technical data pump housing | |
L x W x H | 63 x 63 x 68mm |
Threads | 2x G1/4” |
Technical data pump | |
Speed | 2600 RPM |
Voltage | 6-13,5V DC |
Power consumption | 3,2W |
Maximum flow rate | 72 L/h |
Maximum head | 1 m |
Other technical data | |
Max working temperature | 60 °C |
Pressure tested | 0,8 Bar |
Anschluss: | 2x G1/4" |
Sockel: | AMD AM3/AM3(+)/AM2/AM2(+)/939/FM2/FM1/G34/940;AMD AM5 ;AMD AM4 ;Intel 115x ;Intel 2011(-3) ;Intel 2066 ;Intel LGA 1200 ;Intel LGA 1700; |
Material Deckel: | Kunststoff |
Abmessungen (L x B x H: | 63 x 63 x 68mm |
Liefertermin: in 2 - 3 Wochen
