Alphacool Eiswolf 2 AIO - 360mm RX 7900XTX/XT Taichi - Phantom with Backplate
- Article no.: 13515
- EAN: 4250197135153
- Weight: 5,445 kg
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- ASRock Radeon RX 7900 XT Phantom Gaming OC, RX7900XT PG 20GO, 20GB GDDR6 (90-GA3XZZ-00UANF)
- ASRock Radeon RX 7900 XT Taichi OC, RX7900XT TC 20GO, 20GB GDDR6
- ASRock Radeon RX 7900 XTX Phantom Gaming OC, RX7900XTX PG 24GO, 24GB GDDR6
- ASRock Radeon RX 7900 XTX Taichi OC, RX7900XTX TC 24GO, 24GB GDDR6
Technical data radiator | |
Material threads | Brass |
For fan size | 120 mm |
Dimensions (L x W x H) | 274,10 x 161,15 x 47,52 mm |
Threads | 2 x G1/4“ |
Pump type | DC-LT 2 |
Head of delivery | 1 m |
Maximum flow rate | 72 L/h |
Voltage | 6-13.5V DC |
Power consumption | 3.2W |
MTBF | 50.000 h |
Technical data liquid | |
Color | clear |
Material | Nylon |
Color | Black |
Technical data fittings | |
Quantity 90° fittings | 2x |
Material fittings | Brass |
Technical data tube | |
Length | 50cm |
Color | Matt black |
Tube size | 12,7 / 7,6mm |
Technical data fan | |
Speed | 0 - 2500 RPM |
Air flow rate | 119,8 m³/h |
Bearings | Sleeve bearing |
Fan connector | 4-Pin PWM |
Net weight | 187g |
Radiatordicke: | 29 - 39mm |
Vorbefüllt: | Ja |
Radiatorgröße: | 360mm |
Sockel: | AMD Radeon ; |
