Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 Ventus with backplate
- Article no.: KOI
- EAN: 4250197144209
- Weight: 5,04 kg
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- MSI GeForce RTX 3080 Ventus 3X 10G OC, 10GB GDDR6X
- MSI GeForce RTX 3080 Ti Ventus 3X 12G OC
- MSI GeForce RTX 3090 Ventus 3X 24G OC, 24GB GDDR6X
- MSI GeForce RTX 3090 Ventus 3X 24G, 24GB GDDR6X
Technical data radiator | |
L x W x H | 395 x 124 x 30mm (+/- 3%) |
Material threads | Brass |
For fan size | 120 mm |
Possible fan assembly | 3 x one-sided / 6 x both-sided |
L x W x H | 132 x 259 x 46mm |
Material cooler top | PMMA |
Threads | 2 x G1/4“ |
Pump type | DC-LT 2 |
Head of delivery | 1 m |
Maximum flow rate | 72 L/h |
Voltage | 6-13.5V DC |
Power consumption | 3.2W |
MTBF | 50.000 h |
Technical data liquid | |
Color | clear |
L x D | 95 x 27mm |
Material | Nylon |
Color | Black |
Technical data fittings | |
Quantity 90° fittings | 2x |
Material fittings | Brass |
Technical data tube | |
Length | 50cm |
Color | Matt black |
Tube size | 12,7 / 7,6mm |
Technical data fan | |
Speed | 0 - 2500 RPM |
Air flow rate | 119,8 m³/h |
Bearings | Sleeve bearing |
Fan connector | 4-Pin PWM |
Dimensions | 120 x 120 x 25mm |
Net weight | 187g |
Vorbefüllt: | Ja |
Radiatorgröße: | 360mm |
Sockel: | Nvidia GeForce |
