Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI Founders Edition with Backplate
  • 14476
  • 4250197144766
  • 4,78 kg
€159.98 * €269.98 * (40.74% Saved)
14372 Alphacool NexXxos ST30 Full Copper 360mm prefilled AIO Edition
€109.98*
€12.98*
11951 Alphacool Aurora vertical GPU mount with riser cable
€79.98*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- Inno3D GEFORCE RTX 3090 TI ICHILL FROSTBITE
- Inno3D GEFORCE RTX 3090 TI X3 OC
- Nvidia 3090 Ti Founders Edition
Technical data radiator
L x W x H395 x 124 x 30 mm (±3 %)
Material cooling fins, chambers & channelsCopper
Material threadsBrass
G 1/4 threads2 x for tubes (+ 1x Fillport G 1/4)
For fan size120 mm
Possible fan assembly3 x one-sided / 6 x both-sided
Technical data cooler and pump
L x W x H220.5 x 156.05 x 46 mm
Material cooler bottomChrome plated copper
Material cooler topacrylic
Threads2 x G 1/4
Pump typeDC-LT 2
Pump speed2600 rpm (±10 %)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5 V DC
Power consumption3.2 W
MTBF50.000 h
Technical data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 °C / +90 °C
Technical data quick fasteners
L x D95 x 27 mm
MaterialNylon
For tube size12.7 / 7.6 mm
ColorBlack
Technical data fittings
L x D straight fitting24 x 18 mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17 mm
Quantity 90° fittings2x
Material fittingsBrass
Technical data tube
Length50 cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12.7 / 7.6 mm
Hardness grade35 Shore A to 50 Shore D
Working temperature-50 to +155 °C
Technical data fan
Speed0-2500 rpm
Static pressure3.17 mmH₂O
Air flow rate119.8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Connection Digital aRGB3-Pin JST + 3-Pin 5 V
Dimensions120 x 120 x 25 mm
Net weight187 g
Max working temperature60 °C
Technical note!
Due to long storage times and various transport routes, the liquid in the AIO remains still for a long time. The ingredients of the liquid can therefore deposit and lead to a brownish discoloration. As soon as the pump starts operating, the ingredients mix again and the liquid should regain an approximately clear color. This is not a reason for complaint as neither the performance nor the function of the AIO are restricted by this. If the discolouration of the cooling liquid does not disappear after the AIO has been put into operation, please contact our support team via E-Mail (info@alphacool.com). You will receive quick and uncomplicated help there.
€6.49 * €8.98 *
