Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 Suprim X with Backplate
- Article no.: 13069
- EAN: 4250197130691
- Weight: 5,42 kg
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- MSI GeForce RTX 3080 Gaming X Trio 10G, 10GB GDDR6X (V389-005R)
- MSI GeForce RTX 3080 Gaming Z Trio 10G, 10GB GDDR6X (V389-045R)
- MSI GeForce RTX 3080 Gaming Z Trio 12G LHR, 12GB GDDR6X (V389-402R)
- MSI GeForce RTX 3080 Suprim X 10G, 10GB GDDR6X
- MSI GeForce RTX 3080 Suprim X 12G LHR, 12GB GDDR6X
- MSI GeForce RTX 3080 Ti Gaming X Trio 12G
- MSI GeForce RTX 3080 Ti Suprim X
- MSI GeForce RTX 3090 Gaming X Trio, 24GB GDDR6X (V388-011R)
- MSI GeForce RTX 3090 Suprim X 24G, 24GB GDDR6X
Technical data radiator | |
L x W x H | 395 x 124 x 30mm (+/- 3%) |
Material threads | Brass |
For fan size | 120 mm |
Possible fan assembly | 3 x one-sided / 6 x both-sided |
L x W x H | 295 x 161,9 x 46mm |
Threads | 2 x G1/4“ |
Pump type | DC-LT 2 |
Head of delivery | 1 m |
Maximum flow rate | 72 L/h |
Voltage | 6-13.5V DC |
Power consumption | 3.2W |
MTBF | 50.000 h |
Technical data liquid | |
Color | clear |
L x D | 95 x 27mm |
Material | Nylon |
Color | Black |
Technical data fittings | |
Quantity 90° fittings | 2x |
Material fittings | Brass |
Technical data tube | |
Length | 50cm |
Color | Matt black |
Tube size | 12,7 / 7,6mm |
Technical data fan | |
Speed | 0 - 2500 RPM |
Air flow rate | 119,8 m³/h |
Bearings | Sleeve bearing |
Fan connector | 4-Pin PWM |
Dimensions | 120 x 120 x 25mm |
Net weight | 187g |
Vorbefüllt: | Ja |
Radiatorgröße: | 360mm |
Radiatordicke: | 29 - 39mm |
Radiatorabmessung: | 395 x 124 x 30 mm |
Sockel: | Nvidia GeForce |
![KOI Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 FTW3 mit Backplate](https://aquatuning.shop-cdn.com/media/image/54/48/ee/1020892_1sck9UZESD4Jv7_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800/6800XT Gaming Trio X mit Backplate](https://aquatuning.shop-cdn.com/media/image/a5/5e/9e/1020900_1mLcu2WW3SaXcK_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800/6800XT Strix/TUF with Backplate](https://aquatuning.shop-cdn.com/media/image/70/51/49/1021887_1FO7goJvCrT2qu_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm RTX 4080 Reference Design mit Backplate](https://aquatuning.shop-cdn.com/media/image/68/f6/48/1023273_1Hj46VqBnwiHVx_200x200..jpg)
![WÄM Alphacool Apex 17W/mK Thermal grease 4g](https://aquatuning.shop-cdn.com/media/image/2b/b5/16/1022240_1gxSgfGrdtkDJV_200x200..jpg)
![S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - Ultra Clear 3m (9,8ft) Retailbox 300cm](https://aquatuning.shop-cdn.com/media/image/2b/ba/c9/1019548_1KA2xVJXgo7bKU_200x200..jpg)
![S16 Alphacool Eisrohr 16/13mm Acryl (PMMA) HardTube Satin 80cm - 4er Set (320cm)](https://aquatuning.shop-cdn.com/media/image/75/b3/cf/1012480_1ypXowBqBIIK6L_200x200..jpg)
![KAB Alphacool Y-Splitter aRGB 3-Pin auf 4x 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/a1/78/b1/1023149_01_200x200..jpg)
![WAGZ Alphacool Eisschicht Ultra Soft Wärmeleitpad 3W/mk 100x100x1,5mm](https://aquatuning.shop-cdn.com/media/image/80/b9/b7/1023008_15V7tjSuKcBB2v_200x200..jpg)
![ANS Alphacool Eiszapfen 16/10mm Anschraubtülle G1/4 - White Sixpack](https://aquatuning.shop-cdn.com/media/image/d0/93/54/1022523_01_200x200..jpg)
![ANS Alphacool Eiszapfen 16/10mm Anschraubtülle 90° drehbar G1/4 - 4pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/d7/e8/e2/1022487_19nEvBCZPcevCB_200x200..jpg)
![ANS Alphacool Eiszapfen 13/10mm Anschraubtülle 90° drehbar G1/4 - 4pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/aa/3d/46/1022485_1DYrNWrtaKb4bh_200x200..jpg)
![ANS Alphacool Eiszapfen 16mm HardTube Anschraubtülle 90° drehbar G1/4 für Acryl/Messingrohre - 4pcs Set Chrome](https://aquatuning.shop-cdn.com/media/image/cf/37/46/1022484_1ny9NIYewNIzyv_200x200..jpg)
![WÄM Alphacool Apex Soft Wärmeleitpad 11W/mk 100x100x1mm](https://aquatuning.shop-cdn.com/media/image/45/0f/73/1021777_1Rl6gTg254lB60_200x200..jpg)
![WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm](https://aquatuning.shop-cdn.com/media/image/32/00/5e/1021763_1PFyMpyHDB5PBY_200x200..jpg)
![WAZ Alphacool Apex Liquid Blue UV-aktiv 1000ml](https://aquatuning.shop-cdn.com/media/image/81/34/76/1021668_1xprw9hWW8nNyh_200x200..jpg)
Liefertermin: in 5 - 6 Tagen
![S13 Alphacool EPDM Tube 13/10 - Black 3m (9,84ft) Retailbox](https://aquatuning.shop-cdn.com/media/image/6c/ae/02/1021502_01_200x200..jpg)
![WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 FTW3 mit Backplate EOL](https://aquatuning.shop-cdn.com/media/image/cd/b5/37/1020734_1bNijWe0MUygje_200x200..jpg)
Liefertermin: in 8 - 9 Wochen
![S16 Alphacool Eisrohr 14/11mm PETG HardTube 80cm - 4er Set (320cm)](https://aquatuning.shop-cdn.com/media/image/11/4e/b0/1019801_12FdZKxXcw2S2n_200x200..jpg)
![ANS Alphacool Eiszapfen 14mm HardTube Anschraubtülle G1/4 - Deep Black Sixpack](https://aquatuning.shop-cdn.com/media/image/28/92/0d/1019798_1lZz6kkuUJeQu1_200x200..jpg)
