Alphacool y-splitter aRGB 3-pin to 2x 3-pin 60cm
  • 18706
  • 4250197187060
  • 0,027 kg
€4.68 *
Content: 60 Zentimeter (€7.80 * / 100 Zentimeter)
€12.98*
€16.99*
€15.98*
€18.98*
A high quality sleeved aRGB 3-pin to 2x 3-pin Y-splitter cable. Compatible with all Alphacool... more
A high quality sleeved aRGB 3-pin to 2x 3-pin Y-splitter cable. Compatible with all Alphacool aRGB products as well as most motherboards and aRGB controllers. This Y-splitter can be used to combine multiple aRGB elements.
Length60cm
Connections3-pin to 2x 3-pin
Voltage5V
MaterialPlastic, sleeved
83%
€1.49 * €8.98 *
€2.98 *
83%
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 * €5.89 *
KAB Alphacool Eis-Matrix Verbindungskabel - 10cm EOL
Alphacool Ice Matrix connection cable - 10cm
Content 10 Zentimeter (€9.90 * / 100 Zentimeter)
€0.99 *
€5.99 *
€3.97 *
€2.58 *
€4.38 *
€6.99 *
€2.98 *
€2.78 *
€2.68 *
€5.68 *
€3.47 *
€1.68 *
€2.28 *
Alphacool Core double sided adhesive thermal pad 100x100x0.25mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.99 *
€4.97 *
€3.78 *
€3.88 *
Alphacool y-splitter 4-Pin to 2x 4-Pin PWM 30cm white
€2.98 *
€2.58 *
€5.99 *
€4.48 *
€1.48 *
Alphacool fan cable 3-Pin to 3-Pin extension PWM 60cm
€2.48 *
€2.28 *
Alphacool fan cable 3-Pin to 3-Pin extension PWM 15cm
€1.98 *
€3.47 *
€1.98 *
