Tube PVC 13/10mm (3/8"ID) UV-aktiv Blue/Clear 15m roll
- Article no.: 5100442
- EAN: 4070201004424
- Weight: 1,3 kg
The luminosity of this new UV-active hose has been significantly increased through the optimized use of UV-active additives. The bendability and other technical data have been completely retained compared to conventional hoses. The hose is therefore ideal for creating the best possible lighting effect in the PC. The hose can also be slit to use it as a cable duct, for example.
This highly flexible hose allows for tight bending radii, making it ideal for applications where space is limited. The order quantity corresponds to the required hose length in metres.
For resellers, the hose is available in packaging units of 30 m or 100 m per roll. It is compatible with screw-on nozzles and hose nozzles, but not with plug-in connectors.
Please note:
Due to transport and storage, the hose may arrive at the customer slightly "undercooled". Cold PVC hoses tend to become somewhat hard. To enable optimal installation, we recommend that you either store the hose in a warm room for a few hours after receiving it or place it briefly in hot (e.g. 60°) water before installing it. The hose will then have reached its optimum bendability.
| Technical Data | |
| Dimensions | 13/10 |
| Color | Transparent |
| Fluorescence color | Blue |
