Alphacool Apex Grip HardTube fitting 13mm G1/4 chrome
  • 14884
  • 4250197148849
  • 0,044 kg
  • 5
18439 Alphacool HardTube 13/10mm Acryl clear 60cm - 4pcs
€15.98*
€279.98*
€178.98*
14158 Alphacool NexXxoS ST30 Full Copper 360mm radiator
€66.98*
Technical Data
Height22,20mm
Diameter23,50mm
MaterialBrass
Material Grip SurfaceSilicone
ThreadsG1/4
Thread Length5mm
Hardtube compatibility13mm outer diameter (OD)
Colorchrome
Warranty: 5 years
€36.98 *
